Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5 link vette suspension
Old 11-27-2007, 08:48 PM
techron techron is offline
Originally Posted by adtkart
Techron.... You are right of course, in that it does not move with the suspension. Being mounted thru rubber bushings does not make it very rigid by any standards I know of. Without that connection to the trans, the pinion angle can change by probably 25 deg or more on that model. Some of the other years had plates that bolted directly to the frame. That was rigid.
Aaron
i agree, without the connection to the trans it would probably twist right off, i think 25 deg would be a conservative estamate. i'm doing a 64 now and the third member has a bracket that bolts to the housing directly under the pinion but bolts to the frame with rubber hockey puck bushings above and below the frame bracket so they are not really rigid either.
