Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5 link vette suspension
Old 11-28-2007, 07:20 PM
techron techron is offline
Originally Posted by adtkart
I don't believe I have seen that type of mount. The ones I was thinking about were the ones with a large flat on the rear cover. Was actually thinking about seeing if that cover would fit on my housing. Then I would have to re-engineer the tie-rod (don't know the correct name) for the toe settings, since it is attached to the original cover. I don't like the way the "batwing" looks from the rear under a Model T.
Aaron
aaron, not a real clear picture but of you look at the first pic you can see the U shaped bracket under and foreward of the spring where it bolts to centersection and runs foreward to the frame. that rubber hockeypuck bushing sit between the bracket and frame it's the same from 63-82. you can also see the crossmsmber that holds the rear and bolts to the frame, there is a rubber coffeecup isolater between the frame and crossmember on each end.
http://www.corvettefever.com/project.../photo_01.html
