Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5 link vs independant
Old 12-06-2011, 08:33 AM
1969NovaSS's Avatar
1969NovaSS 1969NovaSS is offline
turbo lag......yeeeeehaaaaaaw
I would opt for a 3 link and a watts link if packaging is not a concern. A panhard bar can make a car act differently depending on which way you turn and which side of the frame it is mounted. A panhard will pull the rear end toward the frame mount. The trick is to get it as long as you can to counter act this the problem is still there. A watts will center the rear end no matter what but its a little bulkier/ heavier.
