Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5 lug disk brake rearend
Old 09-21-2008, 03:23 PM
tomslik tomslik is offline
3rdmember
Originally Posted by Chevrolet4x4s
Why not have the rear axles redrilled fior 5x5"? Then you can do a disc swap using 96 back(IIRC) impala rotors and 4tyh gen f body calipers.
Shane
or use seville (don't remember the years for 5") rotors and calipers.
they'd have the e-brake built in to the caliper...
or late gm pu with 2 wd and grab the rotors and use seville calipers.
or MAYBE use the whole rear (or just the backing plates on out) and a pair of spring perches from CCP (i'm assuming you have coil springs on the back)
