5 lug disk brake rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2008, 07:02 PM
69ChevyC10's Avatar
American Muscle is King
I have a 1969 Chevy C10 and im swaping the 6 lug drums to 5 lug disks i already have a frontend with 5 lug disk from a 71or2 but im not sure what rears i can use besides a 71or2 C10?
Old 08-24-2008, 04:27 AM
'71-'72 are the only ones that will fit and have 5-lug axles. They will also be a little bit wider than what you have now, but there's plenty of room unless you have HUGE tires. But none will have disc brakes unless somebody modified them. The factory only made drum-brake rear ends back then.
There were some later '70 rear ends that were the same width as the '71-72, but they still had 6-lug axles. The axles from a '71-'72 will fit in that rear end, but not in yours.
Old 08-28-2008, 09:44 AM
onebadmerc's Avatar
I need a bucket of arc sparks
The big Lincoln Continentals in the 70's had a 5 on 5 pattern rear disc brake set up pattern on a 9" rearend if you want to go this route.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
Disk brake conversion for a 1953 3/4 ton pickup w/t Junkyard Parts YoungGunRodder Suspension - Brakes - Steering 4 06-26-2005 07:25 AM
ford 8.8 disk brake retrofit to 9" Jared Transmission - Rearend 5 06-02-2005 12:27 PM
79 LTD disc Brake rearend Mike Pomerantz Suspension - Brakes - Steering 2 09-11-2003 12:19 PM
disk brake swap CARGUY Suspension - Brakes - Steering 0 07-22-2002 01:52 PM
