Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5 lug disk brake rearend
Old 03-19-2013, 12:29 AM
surfmurf's Avatar
surfmurf surfmurf is offline
SurfMurf
rear end swap
My '55 2nd series has a 10-bolt '77 Nova rear end w/ Leaf Springs and Drum brakes in it now. Current engine is a SBC 305 w/ TH350 pushing a 2.56 rear ratio. It is 61.0" WMS to WMS.
A stock '55's WMS is 62.0".
I am looking at buying a 1969 1/2 ton 2wd 12-bolt which I read is only 60.5" WMS.
I expect Drum Brakes would be OK, which is what it has. But it is 6 lug, so I'll need new axles and maybe an LDS or Locker with about 3.42 or 3.55 gears. The power will be a modified '69 SBC 302 (ex-Z/28) with Roller Cam and 3-2s driving thru a TH700R4 = 3.06 1st, 1.63 2nd, 1.00 3rd, and 0.70 4th gears.
My concern is the 60.5" 12 bolt versus the 62.0" OEM or even my 61.0" '77 Nova 10 bolt. Not sure what to do to fit her in or even if I should look elsewhere for a wider 12-bolt?
Your opinions, suggestions, knowledge for me please. Murf = world's oldest 1st time street rodder ! ? !
