5 pin connector on a 4L60 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2007, 08:59 PM
5 pin 700r4 is 4l60 no e on the end !
any luck with wiring 5 pin 4l60 ? im in the same boat. swithed from 700r4 4 pin to 4l60 5 pin. wont shift in auto until high rpms. is there an additional solenoid on the 5 pin 4l60 ? hate to pull trans again.
Old 07-29-2007, 09:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
5 pin or 4 pin connector has nothing to do with shifting on the 4l60/700 trans.
Check your TV cable for adjustment , free travel of the cable... slides in & out of the housing easily.
minimum setting is important as the max setting at WOT
Old 07-30-2007, 06:27 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Check this site out. It will show the differences with pictures. Check it right HERE, or maybe a little bit more HERE, then again if you move your mouse HERE
Old 07-31-2007, 03:09 AM
4l60
thanks for the shift info on the 4l60. tv cable adjustment did not change the late shift at high rpm . are you sure there is not a shift solenoid for 1st and 2nd in the 5 pin 4l60? there is two solenoids at the bottom rear of the tranny and it looks like a temp sensor is in between them. i found the correct wires for lock-up in the front. supposed to be a good trans any last ideas before i pull it and go back to 700r4 4 pin ? cant find wiring schematic for the 93 4l60 5 pin if you disconnect the round 5 pin connector on the left side will it not affect the shifting? what are those two electrical devices at the rear ? they have one wire attached to them and they look like a plastic nut about 1 1/2 inch . thanks for your input
Old 07-31-2007, 06:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I have split off this discussion since it has gotten larger than I thought it would... better viewing for folks I hope.
with 3 decades of trans work under my belt ....yes I am sure there are no shift solenoids on a 5 pin connector 4L60.
The late shift at high RPM , may be a stuck TV cable, inner TV valve in the v-body ..... A TV cable on this trans is also an indication the trans is NOT a 4l60E trans with shift solenoids.
The items on the rear of the valve body you describe sound like pressure switches .
a photo of v-body with pressure switches;
these pressure switches may not look eggzackly like what is on your v-body.
here are shift solenoids common to a 4L60E trans..:
Old 08-01-2007, 02:28 AM
back to 700r4
thanks for all the info on 4L60 trans! scored a fresh 700r4 today so i will pull the 5 pin tranny out and stick with the 4 pin 700r4. any problems on the 1985 model that should be updated while i still have it on the bench ? i will check tv spring of course and change out lockup solenoid for insurance.
