5 point harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2006, 06:00 PM
5 point harness
Offroadn1 here for the first time. I have a 1995 jeep wrangler with 25,000 original miles, it is bright red, with 13 x5 Toyos, a four inch lift, a Warn winch, hella lights, and mastercraft seats. My questions can you install the 5 point harness to the back floor, without putting up a cross link roll bar or right or left supports. I hear both sides some say yes, some say no, any ideas? Thanks for your time, I look forward to gathering of knowledge.
Old 03-06-2006, 09:32 PM
Ya can
You can install belts to the floor, drill a hole in the floor and put a 6"x6" plate under the floor for it to bolt to. Be warned though, this type mount is not nearly as effective as cage mounts. Hope this helps.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Wiring Kits crazygutgut Electrical 40 12-15-2005 07:49 AM
changing engine wiring harness, ran into a lil problem ikeaguirre14 Electrical 9 06-02-2005 05:01 PM
5 point harness into a factory seat is it possible... stonedchihuahua Interior 13 01-04-2003 01:03 PM
