Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5 SPD manual wont install all the way
Old 06-08-2006, 06:37 AM
Greg55_99 Greg55_99 is offline
Try putting a wrench and socket on the crankshaft bolt and turn the engine over by hand. That may help seat the input shaft. Also make sure you've installed the clutch disk the right way around. Some clutch disks have the hub offset towards the engine and if it's pointing at the tranny end, it will bottom out on the front bearing retainer collar.
