Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5 SPD manual wont install all the way
Old 06-08-2006, 12:23 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
Or you could try pulling it in gently with the transmission mounting bolts.
Not a good idea. Do you have the trans in gear? If so, you can turn the output shaft to line the splines up. Also, if the bushing is peened at all, it will make the install much harder.
