5 speed to automatic - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2012, 10:42 PM
can anyone give some advise about speedometer. I replaced cluster ,speed sensor ,check the wiring. the trans is 700r4. a friend told me it was a cable that should hook up behind the cluster but i don't see one and the other trans didn't have one help please
Old 03-07-2012, 07:53 PM
Canzus's Avatar
a red wool sock on his dinger
What was plugged into the tail housing on the 700R4? Maybe you could plug that into the new tranny...
Just a guess on my part...
Old 03-07-2012, 08:19 PM
well the same plug fit but still didnt work so i replaced the sensor
Transmission ID - 2 speed automatic bbuss Transmission - Rearend 10 12-31-2009 01:31 PM
5 speed or automatic?? 49fordp/u Transmission - Rearend 1 05-21-2009 12:57 PM
Looking for a 4 speed automatic brad1 Transmission - Rearend 7 02-22-2009 10:34 PM
Six Speed Automatic? MartyMart9@aol.com Transmission - Rearend 9 09-03-2004 07:42 PM
from 5 speed to automatic bronco 2 Transmission - Rearend 2 08-24-2002 03:56 PM
