Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 08-31-2004, 10:12 PM
twigg twigg is offline
5 speed gm trans
I bought a 5 speed trans at a swap meet, it has a piece of tape on it that says GM BW 75. The problem is I can't find any info on a Borg Warner 75? Is there such a thing? If so is it light, medium or heavy duty? Thanks for any help that you can give me.
Old 09-01-2004, 05:27 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Overqualified Underacheiver.
 M&M CUSTOM's barnstar
re: 5 speed gm trans
It wouldn't happen to be a T-5 would it.
Old 09-01-2004, 11:56 AM
dmc12mk3 dmc12mk3 is offline
How many teeth are there on the input shaft?
Is reverse up and to the left or down and to the right?
Old 09-01-2004, 05:23 PM
The input shaft has 10 splines and it has the same mounting as a muncie 4 speed, after closer inspection the BW75 may be BW T5.
Old 09-03-2004, 07:19 AM
Sounds like one of the older T-5's, I believe Monza's had them. Once you get around 250 ft/lbs put to it, you will more than likely run into input shaft bearing problems. I consider these light duty transmissions. I have one laying in a trash pile behind the shop.
Old 09-04-2004, 11:22 PM
classic_chevy_guy's Avatar
classic_chevy_guy classic_chevy_guy is offline
70Chevelle/91Eclipse
i have the same transmission, and i just bought it off ebay, it came out of a v8 83 camaro and im in the process of rebuilding it, and ive been told that there are heavier dutier bearings that can be substituded for the old ones, and should be able to take a little bigger beating. how much power are you planning on running through it???
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
