5 speed trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2006, 11:17 PM
5 speed trans
Hope someone can give me some answers to my questions. I have a 57 chevy hardtop with a 327 small block and a super T10 Borg Warner 4 speed trans. My numerous questions are as follows. What would be the easiest conversion to a five speed trans, and what work would it entail? This car has an original style bench seat. Would this be a problem for the shifter? would the trans tunnel have to be reshaped? would the driveshaft have to be modified. Could I get this five speed from a wrecking yard,and what could I be expecting to pay for this trans? Also could I use the same stock clutch set-up or would I have to switch to hydraulic clutch throughout bearring?
Thanks for any help you can give me
Old 05-21-2006, 03:00 PM
Old Yeller 1970's Avatar
Loud Pipes Save Lives
A Tremec 5 Speed is one option. You can find out more info about installing one in a Tri-5 here.
Old 05-21-2006, 10:44 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Welcome to the site
T-5s will adapt to the stock bellhousing and clutch with an adapter plate.
Looking at the knowledge base on this site, you should find a link to a T-5 site that lists all the trans code numbers, torque ratings, and what they came out of. Code # on the side of the trans and on a tag= such as 187, 204, etc.... are the number you need. It is also ink stamped on the drivers side of the transmission in black letters about 1/2 in high.
Finding a decent World Class transmission out of a Camaro or 90+ Mustang (300 lb ft rated) should not be difficult and about $ 500 give or take.
Stock T-5s in Mustangs take a lot of abuse at the strip behind heavily modified engines. The # 1 thing you need is a PRO 5.0 brand shifter. # 2 is synthetic ATF fluid. Experience has shown that the T-5 can take a beating and keep on ticking.
A T-5 will fit your floor, but the shifter will be about 2 inches farther rearward than you would prefer. Using a tail housing from a S-10 pickup T-5 will move the shifter several inches forward for a neat installation.
Old 05-22-2006, 07:53 AM
Steve karch's Avatar
I just installed a Tremac TKO600 in my 65 Beaumont. I had to do some trans tunnel surgery to fit but it was fairly easy and cut the driveshaft to fit. Otherwise it bolts up to the stock bellhousing and uses stock clutch linkage and crossmember. I bought mine from Keisler Engineering and they were very helpful. You buy them as a kit and there are something like 8 shifter positions so your should be ok with the bench seat. I gained almost 10 mpg on the highway with this trans (.64 od)
5 speed borg warner trans specs martion Transmission - Rearend 3 11-23-2005 04:11 PM
AXOD Ford trans rebuild advice. 4 Jaw Chuck Transmission - Rearend 22 03-16-2004 05:37 PM
ford 4 speed manual trans interchange FASTFORD Transmission - Rearend 2 01-20-2004 03:35 PM
qyestons about a 3 speed trans chevellenut Transmission - Rearend 5 12-13-2003 09:39 AM
5 or 6 speed trans 47cnvert Transmission - Rearend 5 03-01-2002 12:08 PM
