I bet you that the truck tranny is geared more for torque, rather than speed............Just my thought on the matter.
Ontario Rodders |
don't know, I know the 1970's and 80's ford truck 4spds were newer variations of the Toploader 4spd, as is the granada/monarch 4spd. have to find out who made them and what trans # they are, probably a diffrent trans between 4x4 and 2x4 trucks
Can't help on the 5-Speed off the top of my head, but on the '70s Ford Truck 4-Speeds, you're dealing with either a BW T18 or NP435. Both are rock solid trannys. I prefer the T18 with the Reverse in the Bottom Right position (vs Upper Right), as it has a monster first gear (6.62:1, I believe). Just rebuilt mine with a kit from Jeff's Bronco Graveyard, although it really didn't need it when I got into it. And that's with 260k hard miles. Only downside is that first isn't sychro'd on these trannies.
Hope that helps some. |
What Matt said. Bottom line is 1st to 2nd shifts are fine, but when you're coming to a stop, you either double clutch or wait until the truck is stopped before going from 2nd to 1st. Don't even think about making this shift when trying to engine brake a load.
Comparing a T5 to a T18 is like comparing Mesa Verde to Petra. Extra points for anyone who gets that analogy. |
5-speed from a truck
Mesa Verde,a beautiful park in Colorado,must be the T-5.
Petra,an ancient,dry barren city in Jordan. Behold The power of the internet!! |
yes but isn't a t18 a 4 speed from the 70's i was talkin about the 5 speed that came in 2wd trucks behind 460's in the lated 80's and 90's not sure if its the same tranny but there was also 5 speeds behind 5.0's and 351's
If you don't find your answer here, try these sites, but I warn you that they're much less PC & friendly. www.pirate4x4.com www.fordtruckenthusiasts.com Best of luck! |
ok for any one interested zf has gear ratios of:5.72, 2.94, 1.61, 1, .76
and was used on f-250's and up. f-150's had a mazda tranny with a 3.90 first gear the zf will have 2 pto covers on the bottom sides of the tranny and have diagonal cross hatching the madza will not have pto covers and has vertical crosshatching. lol with a first like that you could run a 2.35 rear |
Course I can walk faster than my truck goes in 4th-Lo-Lo... |
Grew up in close proximity to Mesa Verde (picture 1) & hearing what an incredible feat it was for the Anasazi to create in 600 AD. Then, in the '90s, while stationed in the Middle East, I toured Petra (picture 2), also 6th Century AD, and was astounded. Makes Mesa Verde look like building with lincoln logs. |
Derm, you must rock crawl? I'd like to see pictures of what you've got if you have any.
BTW, those are cool pictures. The picture of the building in the rock looks like one of the locations in Indiana Jones. Did they film there or was that a studio prop of that building? Is Jordan safe for Westerners? It'd be really neat to tour some of those ancient Middle Eastern sites but these days I'd be concerned for my safety. |
| Chev truck 4 speed shifter fix? pic | MM in NM | Transmission - Rearend | 2 | 05-19-2006 06:21 PM |
| replacement pickup truck - your advice please | jojo99 | Hotrodding Basics | 7 | 05-03-2006 10:52 PM |
| replacement pickup truck - your advice please | jojo99 | General Rodding Tech | 6 | 04-28-2006 01:18 PM |
| striaght 6 swap into a 55 ford truck | brett 6868 | General Rodding Tech | 1 | 06-11-2004 10:51 AM |
| 66 ford truck swapping a 240 i6 out for small block chevy | igotachevyor2 | Engine | 0 | 04-14-2002 03:19 PM |
