-   -   50 or 60 series (http://www.hotrodders.com/forum/50-60-series-181395.html)
anth's iroc 07-20-2010 05:36 PM
50 or 60 series
got a question,
I have an 87 iroc 400sbc 462 heads 501/501 cam Rpm intake edelbrock 750 carb msd ignition hooker headers hooker exhaust th350 tranny 3.73 gears 3200 stall converter.What i was wondering would a 275/50/15 or a 275/60//15 be a better tire for a 1/4 mile with this car.Based on the info i gave.
Thanks for the help
Anth
sqzbox 07-24-2010 05:36 AM
I believe the 60 would be the choice! The taller tire would be less prone to breaking traction off the line, providing you can fit them under the wheel well's. :D
a1supersport 07-24-2010 06:01 AM
There's almost a two-inch difference in tire height, between the two. The type of tire is important too. What kind of tires are you going to use?
anth's iroc 07-25-2010 07:13 AM
Either a bf goodrich drag radial or an american racer dot tie with a D compound..
