50 or 60 series - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2010, 05:36 PM
50 or 60 series
got a question,
I have an 87 iroc 400sbc 462 heads 501/501 cam Rpm intake edelbrock 750 carb msd ignition hooker headers hooker exhaust th350 tranny 3.73 gears 3200 stall converter.What i was wondering would a 275/50/15 or a 275/60//15 be a better tire for a 1/4 mile with this car.Based on the info i gave.
Thanks for the help
Anth
Old 07-24-2010, 05:36 AM
sqzbox's Avatar
My pipes are my music
I believe the 60 would be the choice! The taller tire would be less prone to breaking traction off the line, providing you can fit them under the wheel well's.
Old 07-24-2010, 06:01 AM
There's almost a two-inch difference in tire height, between the two. The type of tire is important too. What kind of tires are you going to use?
Old 07-25-2010, 07:13 AM
Either a bf goodrich drag radial or an american racer dot tie with a D compound..
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
Good Traction 15" /70 Series Tires ??? acr Suspension - Brakes - Steering 8 10-16-2006 07:02 AM
ring and pinion for a 2 series carrier jody chevelle Transmission - Rearend 4 12-06-2005 10:24 PM
gm 10 bolt series I.d. tkett32 Transmission - Rearend 6 07-03-2005 07:16 PM
54 chevy ? pichoboxing Hotrodders' Lounge 11 07-29-2002 06:32 PM
