50 chevy pu fuel tank options - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2005, 11:46 PM
fat50chevy's Avatar
New Member
Glad to report that I finially got my truck ( a 50 chevy 1/2 ton pu ) inspected, tagged and almost on the road. I have a fuel tank problem and I'm hoping for some suggestions. My fuel tank is a stock (Behind the seat) tank. It has no leaks and I get no fumes, but I am having to change my fuel filter way too much, junk in the tank. I cleaned out the tank myself before installing it, not good enough. I called the local radiator shop today about cleaning and coating the inside ( $125.00 ). I am looking for some options and suggestion in what other tank would best fit under the bed. If I have to spend $125 maybe I can find something for that price that will work under the bed and get that thing from behind the seat. What have you used ? THANKS
Old 08-31-2005, 08:15 AM
A lot of rodders use a 65 Mustang fuel tank.......repro....
Works with just a little work....
Is your truck still 6V or has it been changed to 12V ?
Fuel level sender is the only issue........
Old 08-31-2005, 06:24 PM
Wiki Edits: 49
I made my own out of 14 ga. steel. Took a little time but it fits perfectly, holds about 22 gallons and cost about $25 (for the sealer) the steel was left over from another project.
Old 08-31-2005, 08:45 PM
fat50chevy's Avatar
New Member
Thanks decue and centerline. Decue, I changed it over to 12v, got me a wiring harness from It's A Snap and it worked great. Have you seen those Mustang tanks in a truck like mine, and what kind of work? I know you would have to mount it and make a door but is there anything else. I just put in new Auto Meter gauages, do you know if the sending unit would work. And Centerline I looked at your photos of the tank it looks great but I don't have your skills. Thanks for both of your suggestions, if you have anymore or if someone else has please send them my way, THANKS
Old 09-03-2005, 03:35 PM
Tazz
I would have it cleaned out....
but not sealed...no need unless it is rusted really bad....have them clean it out and install another filter. The stock tank is fine.
Tazz
88 chevy pu tbi troubles bond Introduce Yourself 5 10-17-2004 10:25 PM
Fuel filler hose for 1977 Chevy C20 Terje Engine 0 07-18-2004 10:52 PM
Need help on dual fuel tank wiring on 86 chevy truck shockers69 Electrical 2 12-26-2003 11:09 PM
