50 chevy truck rear end
Hello:
I'm Larry and I'm restoring a 50 chevy truck. There was a previous post on this site that asked about putting in a new rear end that will fit the frame. Please let me know how to measure and what kind of rear end to get for a 350 engine. Thanks alot. |
Hi and thanks for the ideas. I have new springs and mount plates so all I need is the rear.
I have used S-10 rears. The 4-WD is wider than the two wheeler..
| The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post: | ||
doubletree (07-07-2012) | ||
There are probably many rear end that will fit under your truck if you are going to cutom fit the mounts, I've even seen ford 9 in under them. You can fit the tires where you want them by using the right off sets on the wheels.
| The Following User Says Thank You to jfmmck For This Useful Post: | ||
You have a nice looking truck. Thanks for the help.
One of the most important things is to know what tires and wheels you plan on running. I wanted very wide tires on my truck and completely filled the gap between the bed sides and fender lip with tire. For this I used a 67 Camaro rear end (didn't even need to change the spring mounts) and ran 5/16" spacers behind the wheels to get that perfect location being I wanted the widest tire I could get in there.
Brian |
| The Following User Says Thank You to MARTINSR For This Useful Post: | ||
doubletree (07-09-2012) | ||
Generally you measure from the outside axle flange to outside axle flange. Depending on how much tire you want a rear with around 58" is about right for your restored truck.
| The Following User Says Thank You to Mojo56 For This Useful Post: | ||
| 1957 Chevy truck rear end. | speedydeedy | Transmission - Rearend | 3 | 12-07-2010 02:55 PM |
| 50 Chevy truck rear end width? | Father & Son | Suspension - Brakes - Steering | 3 | 08-12-2010 01:49 PM |
| Ford 9" rear end vs stock 89 chevy truck rear end | jimmy p | Transmission - Rearend | 2 | 12-07-2005 03:28 AM |
| 71 chevy truck rear end | choppy71 | Transmission - Rearend | 14 | 09-23-2005 01:55 PM |
| rear end for my 36 chevy truck | leroux | Transmission - Rearend | 0 | 06-13-2002 07:44 AM |
