50 chrysler starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2013, 12:26 PM
50 chrysler starter
Hi gang, I'm converting my 50 Chrysler from 6v pos ground to 12v neg ground. Need a 12v starter and solenoid. Engine is inline 8. Is there such a creature? Will a, say Plymouth 12v inline 6 starter work on my big baby?
Thank you in advance...........danielmeguel
Old 01-16-2013, 01:21 PM
The 6V starter will work fine on 12V, it will just spin faster (not a bad thing). I did this conversion on a 1952 farm tractor and kept the 6V starter.
Old 01-16-2013, 10:36 PM
1950 chrysler starter
Thank you, but what about the solenoid? Mine is a 6v pos grd and is mounted on top of the starter. Where can I get one? Is it possible to mount a ford type solenoid mounted on inner fender wall and run the battery cable to it? Thank you in advance. Danielmeguel
Old 01-17-2013, 09:14 AM
curly5759's Avatar
I agree with Joe, the original starter will work fine. I purchased a 41 Caddy with the original drivetrain. Not knowing it was positive ground, I hooked up a 12 volt battery with the ground as negative. Engine started and ran fine. Generator wasn't working so it wasn't an issue.
I'm currently running a 6 volt starter on my 1950 Caddy, it doesn't mind the 12 volts at all.
Curly
Old 01-17-2013, 08:43 PM
Thank you. what about using my 6v pos starter soleniod which is mounted on top of the started.
Old 01-17-2013, 10:03 PM
curly5759's Avatar
I used the original solenoid, both mounted on the starter (1941 an 1950) with no issues.
curly
Old 01-18-2013, 07:12 AM
Wiki Edits: 27
starter wiring
The way the starters are wired internally it doesn't matter if the system is Neg or Pos ground. We used to put 6 V starters in 12 V cars to get them to start in below 0 weather, just don't crank it very long or you could burn out the starter.
changed from oem starter to high tork mini starter , wires .? don wills Electrical 2 09-04-2010 05:34 PM
starter grinding update Powermaster starter question RossR90 Engine 2 08-11-2008 02:46 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
i'm new, with a 29 chrysler c_illes Introduce Yourself 2 02-23-2007 06:20 AM
starter help 41 chrysler sideshowbobottawa Hotrodding Basics 4 04-23-2006 12:25 AM
