'50 ford pick up steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2011, 03:20 PM
I would like to improve the steering on my all original 1950 Ford F100 pick-up. I don't need power steering but would like to convert to rack and pinion. Any one have any suggestions about what might work best in this truck ?
Old 11-03-2011, 04:09 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
To my mind what would work best is to go to Borgeson (borgeson.com) and get a new replacement steering box and then go through the kingpins and bushings and tie rod ends. When this is done the truck will drive just fine and the wobbly steering will be fixed.
Sam
Old 11-03-2011, 05:22 PM
Thanks ..I will look into that but am afraid that the old '50s set up with a steering box ect.. will still have too much "play"
Old 11-03-2011, 06:19 PM
Wiki Edits: 3
The play you have now is most likely from worn parts..just my opinion but I do know that when new that type of steering and axle works fine..
Sam
Steering improvement for '50 Ford Pick - up ? roddinginvt Hotrodding Basics 4 11-04-2011 10:35 AM
Pick rolling chassis ford '37 ford 1 1/2 ton fxfxr Hotrodding Basics 11 07-20-2009 08:57 PM
65 ford pick-up? dougie fresh Transmission - Rearend 3 06-21-2008 03:57 PM
41 ford pick up Fizzy Introduce Yourself 4 04-10-2008 09:37 AM
51 Ford Pick Up mercury man Transmission - Rearend 4 03-22-2008 03:44 PM
