Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 50 ford rack and pinion help
Old 03-03-2006, 08:48 PM
Deuce Deuce is offline
As a moderator here, I would like to WELCOME YOU HERE... `
Your friend has gotten caught up in the rush to ' rack and pinion ' like a lot of folks...... Rack and Pinion steering is not a simple bolt on....as friend has found out. Everything has to be engineered together. The arms and tie rods have to have the same travel arc as the lower A arm ......or bump steer will be present.....
