50 ford rack and pinion help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2006, 07:01 PM
posting this for a friend. He has a 50 ford 2dr and he installed a 91 Tarus steering rack unit. He shortened the steering arms on the spindles and the left tie rod. The now has bad bump steer to the left when he hits a bump. What's the cure?? Thanks JK
Old 03-03-2006, 07:48 PM
As a moderator here, I would like to WELCOME YOU HERE... `
Your friend has gotten caught up in the rush to ' rack and pinion ' like a lot of folks...... Rack and Pinion steering is not a simple bolt on....as friend has found out. Everything has to be engineered together. The arms and tie rods have to have the same travel arc as the lower A arm ......or bump steer will be present.....
Old 03-05-2006, 06:40 PM
what to do next to fix
So to fix this do we need to just set the rack so that it's in the same plane as the lower arm. ?? thanx JK
Power rack and pinion 1954-55 Ford Hemi Boy Suspension - Brakes - Steering 0 02-12-2006 03:16 PM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 12:53 PM
'59 Ford Rack and Pinion kevkoracing Suspension - Brakes - Steering 7 08-22-2003 01:44 PM
Rack and pinion CustomFord Suspension - Brakes - Steering 2 01-29-2003 05:30 PM
92 Buick power rack pinion using 68 Ford pump? JAY221 Suspension - Brakes - Steering 2 09-14-2002 11:21 AM
