50 merc hood pull - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2011, 10:45 AM
bsa_bob2's Avatar
50 merc hood pull
My merc is so stiff [hood cable] that it takes two hands to pull it. It has a chrome t- handle, Has anyone ever , tried replacing just the cable, before i remove it and mess it up.If i cut the end off, at the hood catch it won't be long enough to use again, i can't find repops of this particular cable .in any of my parts house books!! bob s Any help as usual appreciated. thank you
Old 08-22-2011, 11:34 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Mcmaster Carr has push/pull control cables so try them for something suitable..
Sam
Old 08-23-2011, 05:24 AM
deadbodyman's Avatar
Wiki Edits: 11
Before you replace the cable try spraying some PB blaster in there and working it back and forth if it isnt kinked or frayed,that should do it.
Old 08-23-2011, 11:22 AM
bsa_bob2's Avatar
I greased up the upper hood center pin and adjusted it. I hadn't ever put grease on that pin when i first built the car, Seems a whole lot better-and i'll look again And see if there is enough fall front to back on this cable for blaster to run the length of the inner cable---which i know was never oiled either when built also thank you bob s
Old 08-23-2011, 03:36 PM
Wiki Edits: 11
Once you have everything lubed up and working freely it still might not work ez but its the best place to start with a 60 yr old car.....the latch may need adjusting a tad..chances are if you have to slam the hood to get it closed thats the main problem.lube those hinges too...
Replacing a metal hood with a fiberglass hood dasyhard Body - Exterior 9 07-12-2011 10:18 PM
Hood pins verse stock hood latch 62440 Body - Exterior 3 08-23-2010 09:30 AM
Fiberglassing a hood scoop on a metal hood Quarter Flash Body - Exterior 11 09-25-2007 06:22 PM
Poll: Showing cars - Hood up or hood down? loyter Hotrodders' Lounge 23 06-24-2007 06:21 AM
Brakes pull right, Brakes pull left, I want to stop straight. 57 Chevy Suspension - Brakes - Steering 7 07-23-2006 05:00 PM
