50 ply - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2012, 05:03 PM
50 ply
Hello, I am new to the flathead world and I have to say it can be a little tough at times. I am working on my 50 ply' spec' deluxe. I have been able to locate most parts, but I am having a hard time finding performance parts, like intakes,headers, and carb's. any suggestions will be greatly appreciated!! I am in North Carolina
Old 08-01-2012, 07:05 PM
Wiki Edits: 27
ply-do parts
My son has a 36 plymouth and on the bulletin board in the shop has Ply-do parts listed I have no idea of what they carry. Back in the 50's we made our own. You could buy a carb adaptor,cut holes in your manifold and weld it on, I Split my Chevy exhaust, made the adaptor and welded it on. You have to heat the manifold to a dull red heat in the BBQ. weld it, then a Slooow cool down. I added Carb mounts to My corvair dunebuggy, I mounted the combo head-manifold in the Milling machine, step bored the holes, then made tubes with a top plate with a carb hole and 4 5/16 holes, 2 match the carb . I used epoxy and pressed them in and drilled and tapped 2 holes in the manifold for studs to hold the adaptor down, My brother bought a U fab log manifold kit for 6 carbs for his Hemi, some one is making then again. weld them your self do a search for Ply-do and you will find lots of info about rodding one.
Old 08-01-2012, 08:26 PM
BOBCRMAN@aol.com's Avatar
Try these guys Clifford Performance :: Make 6 = 8
Old 08-02-2012, 11:43 PM
hkestes's Avatar
48 Plymouth Club Coupe
Try Edgy Speed Shop Edgy Speed Shop for dual carb intake, finned aluminum head.
Langdon's Stovebolt Engine Co. Langdon's Stovebolt Engine Co. | Specializing in GM 6 Cylinder High Performance Parts dual carb intake, cast iron headers, HEI distributor.
Rusty Hope Rusty Hope for disc brake kit, spit stock manifolds
Here are a couple photos of my 230.
The Following User Says Thank You to hkestes For This Useful Post:
kiddrules (08-04-2012)
Old 08-04-2012, 08:40 AM
Than
Old 08-04-2012, 08:52 AM
Thanks, Have a great day
Old 08-04-2012, 08:56 AM
motor looks awesome, love the intake and headers, sweet..... Thanks for the info
30 ply 3w imcaracer19 Introduce Yourself 2 03-27-2006 12:50 PM
Ply-Do? polkat Suspension - Brakes - Steering 3 02-05-2006 01:26 PM
37 ply p3 37 ply p3 Introduce Yourself 1 12-08-2005 11:23 AM
37 ply onto different frame? 37 ply General Rodding Tech 6 04-23-2005 09:26 PM
Ply-Do or M.P. Brakes? erikh47 Suspension - Brakes - Steering 2 07-27-2004 09:59 AM
