You didn't say what kind of trans. If auto, that much duration wants 3-3500 converter to launch OK. If you're using an OD trans, I'd want a 3.73 to 4.10 gear in the rear unless you're already spinning the tires. I think you can get that 60' down to 1.8 and still be very streetable...and then you'll start to like that car. I'm also a fan of single plane manifolds with that much cam especially if you don't have the hood clearance to use a spacer.
