500 caddy engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2003, 11:47 AM
500 caddy engine
I just purchased a 1976 caddy with only 69k miles. The engine and trans are in great condition. The car it self has been in a terrible accident, crushing the quarter panels on both sides. I am planning to take out the engine and trans. Can someone give me some tips on what car I can put both in with out having to do an enormous amount of remodeling. This is my first project and im trying to avoid to much hassel with making customized headers and also cramming the huge 500 engine in something thats going to take 4ever. Also if there is anyone who is also working on a 500 engine can you give me some pro's&con's with your project.
Old 06-25-2003, 01:55 PM
deuce_454's Avatar
i believe you want to get a set of pre 71 cylinder heads, it should praise compression and power considerably. bit other than that the 500 bolts up to any BOP tranny, so i would say to buy a 1970 buick skylark project with no engine and put that sucker in there, add a set of decent meats and paint in some cool colour, yellow and black?? or red and black and go have fun
Old 06-25-2003, 02:22 PM
woodz428's Avatar
Troll Hunter
Arrow
It should easily fit eng/trans in any mid size GM and probaly not to hard a fit into a Camaro/Firebird. If you want a Big car, it should be a virtual drop in for any big GM vehicle.
Old 06-25-2003, 02:33 PM
CamaroX
Was the 500 the biggest V8 caddy engine? Even so that would sweet to have in just about any car, not many people would suspect a caddy engine in a Camaro, thats something different and would rock
Old 06-25-2003, 03:16 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Let me know if you got my PM. My comp was acting up and I wanted to make sure you got it. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 06-25-2003, 04:20 PM
E.T. divided by $ spent= Speed
How bout a 500 caddy motor in a Tubbed Gremlin theres an idea............Oh forgot....its taken.
Did you get my PM return???
Old 06-25-2003, 09:35 PM
What car do you want to put the Caddy motor into? It fits into quite a few with minor "Do it your self" mods.
Someone mentioned a Camaro. A 70'-81' Camaro or Firebird would be a good choice. They come with an 8.5" 10 bolt rear that will take the Caddy torque without problems. Two small steel plates welded to the front of the cross member will allow the stock CDV mounts to be used. You will have steering shaft clearance problems that can be fixed by unbolting the column from the firewall and moving it as far to the driver side as possible. You then redrill holes to bolt it back down. Your main expence will be making an oil pan, or finding an Eldo pan with a rear sump.(I am assuming your car is a Coupe DeVille). The CDV manifolds will work. The right side will be tight against the front of the upper A-frame. You can use a 77'-79' 425 manifold that has a dimple to clear. The 425 manifold is a little more restrictive though. Headers on the stock motor will only net you 10 or 12 HP. More as the motor gets built up with speed parts.
In stock trim, your motor will make around 300 HP on a dyno. Stock compression is rated 8.2-1 with a 120cc head(Actual is around 7.9-1). A switch to a set of 425 heads, with 96cc chambers will give you 10-1 compression and a 45HP increase. The early 76cc heads found on 73' and older Cads will bump your compression to somewhere in the 12.5-1 range. Pontiac valves can be used in the 96 or 120cc heads. The 76cc heads use a longer valve. A 2.11" Pontiac intake valve will flow quite a bit more than a stock 2.000" Caddy valve. You can buy an Edelbrock Performer intake for around $250 or get nearly the same results from "Home Porting" your stock cast intake. An easy 25HP can be had by removing the webbing form under the carb and adding a 1" open spacer.
HotRod did a Junk Yard Jewel artical on the 500Cad.
http://www.eldocountry.com/hrmtorque/
Expect a mid 14 sec pass from your first outing. Once you figure out how to hook all the torque the Caddy has to offer, it will run 13's in stock trim with a 2.56 gear. With a cam, compression, and intake mods, you will be knocking on the 12 sec mark. With a 3.08 gear and a 200 shot of spray, low 11's should be expected. To go faster, one should think about forged pistons and rods to replace the stock cast Caddy parts. 10's would be asking a bit much of the stock bottom end......Wouldn't it? Dan
Old 06-26-2003, 10:28 PM
http://www.cad500parts.com
www.500cid.com
Old 06-28-2003, 04:01 AM
New Member
how about one big bad caddy hearse? not gonna go fast but it sure would be cool to see a hearse light up the tires!
Old 06-30-2003, 11:29 AM
Biggarmike's Avatar
Chief Procrastinator
My neighbor had a Caddy 502 in a '58 F-100 pickup years ago, tall enough gears for a top speed of about 80, pulling your house! (at 8mpg)
called that beast the "Fordillac"
Old 01-30-2005, 02:38 AM
Swaped into 76 Ventura
Yea i droped one into a 76 ventura (Same frount clip as the camero) Replaced stock buick 350, bolted right up to the BOP turbo 350
the swap whent pretty smooth, the Caddy eng is wide so the exh.
manifolds hit the upper A-arms i ground the arms for clearance
but i still had to put the engine in at a very sliyt angle. I hung the engine with my hoist in the eng. bay and welded plate between caddy motor mounts and frame.
I biult my own dual exh.
The one thing i wish i had done was re-cam as the stock grind is pretty mild
Fuel econemy was acceptable, lots of torque.
LeGerra Machine
Old 01-30-2005, 06:27 PM
Cad power
The big Caddys make excellent truck engines,lots of torque and good gas milage too.
Old 01-30-2005, 06:51 PM
Troadster's Avatar
Did you guys ever see the article in Hot Rod Magazine were thy put one in a Chevet??
Old 01-30-2005, 07:01 PM
chevette???
Wow,that would be one hairy ride,but FUNNNNNNN.
Old 01-30-2005, 07:10 PM
Troadster's Avatar
Re: chevette???
It was in the article. with 3.00 gears and 26" tiers(used front wheel drive slicks) run I think in the high 13's
Please forgive my pore spelling
