Swaped into 76 Ventura
Yea i droped one into a 76 ventura (Same frount clip as the camero) Replaced stock buick 350, bolted right up to the BOP turbo 350
the swap whent pretty smooth, the Caddy eng is wide so the exh.
manifolds hit the upper A-arms i ground the arms for clearance
but i still had to put the engine in at a very sliyt angle. I hung the engine with my hoist in the eng. bay and welded plate between caddy motor mounts and frame.
I biult my own dual exh.
The one thing i wish i had done was re-cam as the stock grind is pretty mild
Fuel econemy was acceptable, lots of torque.
