500 crank in a 427 tall deck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2005, 04:35 PM
brian12c's Avatar
Would a 500 crank fit into a 427 tall deck? also what kind of power would a stock 427 tall deck make, how much stroke did the stock crank have, how big were the bores, what was its cr, and rod length? thanks, bf
Old 04-25-2005, 04:45 PM
347mustang's Avatar
a 500 what??? the only 500 ci motor from the factory is a cadallic 500...there is a 427 bb chevy and a 427 ford..so what mototr are you talking about?
Old 04-25-2005, 06:35 PM
brian12c's Avatar
its a chevy. what is the biggest crank i can put in it and i basically need all of the stock specs
Old 04-25-2005, 06:52 PM
347mustang's Avatar
454 is the easiest to find...what is the block..a regular 454 and 427 block are the same..there is a 427 truck block also know as a tall deck...that is different...what are you trying to do..list what you have
427 TALL DECK block icebreakr1969 Engine 20 10-07-2011 12:01 AM
427 tall deck question tigsmc72 Engine 5 10-04-2011 06:17 PM
427 tall deck semicrazy Introduce Yourself 1 08-25-2004 01:30 PM
tall deck 427/ bunk or go for it el Engine 3 01-09-2003 07:33 AM
427 Tall Deck Rebuild MudFrog427 Engine 2 10-03-2002 06:57 AM
