I believe it's a 325 HP motor. I know about the groove in the cam. So it's a no go then? The heads don't such enough air? Too much machine work: hardened seats, spring pockets, bigger valves and eye brow and valve shroud clearance? No comments on the cams? Can very mild port work make these heads flow 300cfm @.600 in 20inches? No bigger intake valves? What say you about the cams?
