Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 502/502 cam upgrade
Old 09-11-2003, 07:58 AM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Here are the 2 cams from GM. I would stay with the GM intake its better than the Edelbrock. Get a Good Holly carb for it,
If you can afford it get one with annular booster's for response.
14096209 Hydraulic Flat Tappet "502"
This hydraulic flat tappet "502" is a good street high-performance and marine cam used in the Gen V 502 H.O. engine P/N 10185085. The duration at lash point in degrees (intake/exhaust) is 328/324; duration at .050" tappet lift (intake/exhaust) is 220/220; and maximum lift with 1.7:1 rocker ratio (intake/exhaust) is 500/500.
Valve lash is zero/zero and lobe centerline is 115 degrees.
24502611 Steel Roller
This steel roller is for the 502 and 454 H.O. engines. (Must use distributor gear P/N 10456413.) The duration at .050" tappet lift (intake/exhaust) is 211/230; and maximum lift with 1.7:1 rocker ratio (intake/exhaust) is 510/540.
Valve lash is zero/zero and lobe centerline is 112 degrees.
Luv the smell of NITRO in the morning.
