502/502 ramjet what temp should they run - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2011, 06:18 PM
have 502/502 it runs between 200 and 220 degrees.is this normal
Old 06-19-2011, 06:23 PM
Sounds kinda high. I would think 180-195 degrees at the most. What thermostat and radiator do you have in your car?
Old 06-20-2011, 07:01 AM
Its high for a performance motor, but not excessive. What is the rest of the setup(car, radiator, waterpump, thermostat, weather)
Old 06-20-2011, 01:24 PM
hughj's Avatar
I have the carburated version of the ZZ502 and it normally ran about the same, which according to several engine builders I talked to isn't bad for these newer engines. After all, they come with a 195 degree stat in them. I did however install a new B-Cool rad & dual fans with a 195 on/175 off switch and it follows those guidelines perfectly. Fans come on at 195 and go off at 175. Mine is in a 69 pro street camaro.
Old 06-21-2011, 07:19 AM
thanks to all for your help
Old 09-23-2012, 03:39 PM
karfever's Avatar
38 Chevy Coupe Ram Jet 502
My 502/502
My Ramjet 502 runs the same temps, 200-220, on occasion a bit higher. I have no 'overheating' issues boil over etc. I was told by many that this is normal for this engine. Remember your temp reading is coming from the head (mine does) and not the intake which would tend to read cooler.
502 ramjet no start right coast Engine 14 06-20-2015 09:31 PM
350 ramjet cam ramster Engine 2 02-21-2011 06:26 PM
454 Ramjet W/ Procharger MHenricks Engine 0 08-23-2009 05:52 PM
350 ramjet 2xs Introduce Yourself 2 06-20-2007 10:20 PM
Question about RamJet 350 iceman36 Engine 1 03-07-2006 10:13 AM
