502 heads on Gen IV block - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2012, 01:58 PM
Does anyone know if you cap put 502 Iron heads on a Gen IV (402) block?
Old 06-18-2012, 02:23 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Yes you can if you use the correct Gaskets-
Old 06-18-2012, 03:48 PM
BOBCRMAN@aol.com's Avatar
But, why would you want too? 402 needs SMALL combustion chambers. Not 119+cc. 502's.
Old 06-18-2012, 03:56 PM
502 Heads
I have a new set of 502 heads, and was wondering which way to go, A new set of 502 (rectangle port) or an original set of oval port heads form a 70 Chevelle SS396 (350 hp) that need to be worked. The 502 heads look like they have bigger valves and similar combustion chamber. I have a 1970 model 402 with slightly domed pistons.
Old 06-18-2012, 07:18 PM
Streetability and response wise use the oval ports. The only way you could use the rect-port big chamber heads would be with a piston change to the 375 horse (or higher) pistons. Even then, with the big heads, the compression would be around 10-1 or less.
Old 06-18-2012, 09:19 PM
Thanks guys. Oval ports it is
Mark IV heads on Gen V 454 block Hacksaw Engine 14 07-19-2012 07:42 PM
Gen V heads, Mark VI block SteveJ44 Introduce Yourself 2 11-24-2004 02:15 AM
Gen V heads, Mark VI block SteveJ44 Engine 1 11-14-2004 09:14 AM
gen-V heads on Gen-IV block? deuce_454 Engine 3 05-30-2002 12:11 PM
