Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 502 HO idle RPM
Thread: 502 HO idle RPM
Old 09-03-2010, 09:53 AM
rajsid's Avatar
rajsid rajsid is offline
Originally Posted by cobalt327
If for some reason you find that there's advance coming in even at a low idle, you will need to add a heavier advance spring to prevent this.
You are right, I think the key is to keep the rpm low enough that there is no mechanical advance.
36 total @ 3600 rpm, with vacuum advance disconnected.
The engine is timed at the 502 HO spec. I am getting 3600 @ 36 with the vacuum disconnected. The dist that I am running gives 22 degrees of mechanical. So 36-22=14 is the initial timing that I have set to. Nowhere can I find any reference of the initial RPM.
