Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 502 HO idle RPM
Thread: 502 HO idle RPM
Old 09-03-2010, 10:30 AM
rajsid's Avatar
rajsid rajsid is offline
Originally Posted by cobalt327
14 BTDC sounds pretty good. You might even go for a little more, but you'd need to limit the mechanical to keep the total where it needs to be.
I didn't find an initial timing rpm spec, either. That's why I thought the 800 rpm spec that the Ramjet uses might suffice.
But as long as there's no mechanical advance sneaking in on you and the vacuum is disconnected and plugged, you're good to go.
Good luck.
Cobalt and Bryan,
Thank you so much.
