502 HO idle RPM
Does anyone know the factory recommended idle RPM for a 502 HO motor is?
I was told that the initial timing should be 14 degrees. I am trying to find out at what RPM should I get 14 degrees at. |
I have a 454HO in the 59
Disconnect the vacuum advance and set to 16 as low an RPM as possible I run 16 initial and at 2500 I am about 36-38-----with the vacuum advance hooked up I am close to 50* at 2500. I have a manual trans so my idle is set at 750, altho many set their BBC idles at 900-1000 with automatics What kind of vacuum are you getting at idle-----me--only about 10 |
If for some reason you find that there's advance coming in even at a low idle, you will need to add a heavier advance spring to prevent this. The Ramjet 502 is: Ignition timing: 8º BTDC @ 800 rpm; 36º total @ 5000 rpm. You can compare your cam, etc. to it to see if the 800 rpm should also apply- but I would say it should be a good rpm to use. FWIW, the 502 HO uses (what is shown in this particular spec chart): 36º total @ 3600 rpm, with vacuum advance disconnected. The HT 502 uses: Ignition timing: 4º BTDC |
I didn't find an initial timing rpm spec, either. That's why I thought the 800 rpm spec that the Ramjet uses might suffice. But as long as there's no mechanical advance sneaking in on you and the vacuum is disconnected and plugged, you're good to go. Good luck. |
Thank you so much. :thumbup: http://farm4.static.flickr.com/3334/...545c887e_z.jpg http://farm5.static.flickr.com/4043/...425c2f07_z.jpg http://farm5.static.flickr.com/4035/...d8c1e55a_z.jpg |
Nice ride! My brother in law had a '68 4-speed w/o T-tops about that same color, w/a 400 HP 427. I had basically the same engine in a '69 Impala SS 427 w/TH400 rated @ 390 HP.
I bet that 502 woke it up- what trans do you have? |
| All times are GMT -6. The time now is 02:59 AM. |
