509 on block - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2011, 09:50 PM
75chev4x4's Avatar
509 on block
Hey Guys have a few 350's and cleaned one up tongiht to get it ready for the machine shop. Its the common 3970010 and has the .10 and .20 on the timing cover which some say has high nickel, but nobody knows for sure. Anyway it also has the 509 in between on the timing cover, is this anything significant to the block or make it special in anyway? Doesn't really matter much I think I will use it if it checks out ok, just think all the history on the small block casting stuff is cool. Thanks for any info guys.
Old 02-05-2011, 09:55 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Moved to Basics forum.
Old 02-05-2011, 10:26 PM
DoubleVision's Avatar
I recently scrapped one of these blocks. I`ve seen the 509 on many blocks, but they were all the same 010 casting number and they too had the 10 20 on them. I don`t think it means anything other than perhaps heavy duty block.
Old 02-06-2011, 03:31 AM
SSedan64's Avatar
The 509 is probably an internal Foundry mold/cast #.
The 010, 020 is Tin & Nickle content.>> http://www.chevytech.info/2c42o8.html hopefully it was actually added.
Can You I D a Block & Heads Small Block Chevy please? Rob Keller Engine 19 01-30-2011 08:39 AM
small block to big block swap in a 91 camaro help! Greg O Sandsten Engine 6 11-02-2010 11:02 AM
Long block short block fitted block what do opelitis5 Hotrodding Basics 4 01-10-2010 06:12 PM
Need advise for trade. 408 short block for dart iron eagle block sherman8r Engine 6 12-06-2009 04:37 PM
Lookin for a ************** short block or long block Jarod Lee Introduce Yourself 2 09-24-2009 05:25 PM
