51 chevy 2door delux floor pans - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2006, 06:35 AM
51 chevy 2door deluxe floor pans/trim removel
hello i need floor pans and some patch panels for my 51 chevy 2 door deluxe car. any one know where they sell them or do i have to make my own. i need to know how to remove the outside trim on the car so i can sand it down and paint it. any suggestions on what color i should paint it.thanks kavin
Old 10-08-2006, 06:01 PM
Wiki Edits: 31
www.rustrepair.com has everything you need. as for the trim, it's bolted on the fender spears, have 3 bolts, 1 in the front, 1 in the middle and 1 in the back, behind where you can get to it easilly. open the drivers door and look down behind the inner fender, from under the hood, you will see it. you can get to it from under, reaching through.
Old 10-10-2006, 07:34 PM
captmetal's Avatar
50 chev panels
i'v used panels from emsautomotive w******************om it is the best 50 chev stuff i'v seen watch out of some real crap from low cost dealers or you can call bob **** ***** ****
Last edited by Crosley; 11-30-2014 at 09:56 AM. Reason: commercial contact info removed
51 Chevy 1/2T Pick Up - Front Clip Question mwskopf General Rodding Tech 10 10-14-2015 05:23 PM
51 Chevy Truck Tilt Frontend 51Panel Body - Exterior 14 07-28-2007 09:34 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
51 chevy seats mondo23 Interior 5 08-31-2006 07:09 AM
Corvette rear end in a 51 Chevy p/u 3100 oldford Transmission - Rearend 2 04-30-2002 12:33 PM
