51 chevy 3/4 ton - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2006, 11:52 AM
51 chevy 3/4 ton
Does a 350 chevy turbo interchange with a 200R or 700R that uses the same cross member mounts? Otherwise or are the transmissions the same lenght?
thanks
Old 02-11-2006, 03:22 PM
Short Tail (6") T350, 200-4R, Powerglide, T400 short tail are all the sme length. T350 and 200-4R share the same output shaft spline. 700R4 has same output, but is longer and stronger than 200-4R.
Crossmember are different for all of them
Old 02-11-2006, 04:04 PM
thanks
As a moderator here, I would like to WELCOME YOU HERE ...
Here is a link to a page with all the GM transmission widths, lengths and mounting points
http://www.tciauto.com/tech_info/trans_dims.htm
Again.....WELCOME.....
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
51 Chevy Truck Tilt Frontend 51Panel Body - Exterior 14 07-28-2007 10:34 AM
chevy heads desireable for the rebuild of a 400 for my 3/4 ton 86 2x4. nh32u Introduce Yourself 4 12-17-2005 07:31 PM
Disk brake conversion for a 1953 3/4 ton pickup w/t Junkyard Parts YoungGunRodder Suspension - Brakes - Steering 4 06-26-2005 07:25 AM
Need 51 Chevy 1/2 ton bed oldford Body - Exterior 0 04-12-2002 09:01 PM
