51 chevy gasser stright axle with rack and pinion??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2012, 07:26 AM
Last journal entry: before and after
Hey guys got a question im building a gasser out of my 51 chevy business coupe. Just picked up an axle from a 1960 ford f100 it looks as tho I can make it work but the question I have is would going to a rack and pinion set up reduce the bump steer common with the traditional steering linkage? I want to build a fairly traditional gasser but safer is always a plus any gasser info would be greatly appreciated as this is my first one and I want to do it right. thanks , jake
Old 04-17-2012, 07:33 AM
And o believe I just found the answer lol thanks guys any more info would be appreciated
Old 04-17-2012, 08:16 AM
Wiki Edits: 27
bump steer
Steering geometry can be tricky to get right when doing a lot of mods. With a side mounted steering box like on an old pickup, the drag link should normally be parallel and the same length to be mounted with the hair pin or rear of the spring mount center line . One of the The Boyd Coddington Books has diagrams when using a Cowl or high mount steering box. how all the pieces should be mounted to have the pivot points right. The Jacked up Jeeps and 4 X 4 's use different pieces to get the drag link parallel to the tie rod. MY old willys was scarry on rough roads , backin out of the gas on a turn..It wanted to change lanes..
Old 04-17-2012, 09:36 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
The steering geometry has nothing to do with the kind of steering box used..is the axle you have set up or cross steer (the rod from the box to the spindle runs across the car rather than fore and aft) ?
Sam
Old 04-17-2012, 01:09 PM
Yes it is a cross steer set up but by attaching the rack and pinion to the straight axle allowing them to move together and using a universal joint to line up the column. Now by doing that it will eliminate the effect of the steering linkage angle adjusting due to the vertical movement of the axle but in turn when the axle does move will it improve bump steer or make the problem worse?
Old 04-17-2012, 04:56 PM
Wiki Edits: 3
That introduces a whole lot of other issues when the steering box is attached to the axle with induced movement in the steering column..The stock ford geometry works fine so I would stick with that myself..
Sam
Old 04-19-2012, 06:17 AM
Thank you so much guys think im gonna stick with the cross steer set up from the ford. As I can tell now im about four inches too wide from inside the drums I don't necessarily have to take all of that out just need to get the tires under the fenders what im more concerned with is relocating the spring pads to fit under the frame rails ill be posting some pics later on today once again thanks for all the help
37 Dodge Rack & Pinion on Straight Axle New Bird Suspension - Brakes - Steering 2 02-12-2011 05:27 PM
Rack and Pinion with a straight axle Chris Kemp Suspension - Brakes - Steering 7 01-10-2009 08:15 AM
rack and pinion in a dropped axle 34' hot34coupe Suspension - Brakes - Steering 5 01-08-2009 11:25 PM
Straight Axle and Rack & Pinion Murff Suspension - Brakes - Steering 12 06-15-2004 03:21 AM
Dropped axle+rack and pinion? Halloweenking Suspension - Brakes - Steering 7 09-03-2002 02:41 PM
