51 chevy truck gas gauge not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2009, 06:23 PM
new EZ-wiring 21 circuit wire harness, new 12v gauge in stock cluster, new 12v sender in new tank located behind the seat
there is two posts on the back of the gauge, one is for power the other for the sender, i have those wire hooked up properly. then the wire for the sender hooked up to the one post on the sender.
my gas tank is full and the gauge needle points to empty, Ivie had the gauge and sender both checked by my gauge guy and they worked for him but when i get them home and back in the truck they dont work for me.
so is it correct that if i take the sender wire off the sender and ground it the gauge will go past full? and if it does my gauge works, right. also for some reason if my tank isn't grounded the whole system would't work at all and the gauge would read empty right?
i think im on the right track just wanted some input before i start messing with this again
thank you,
Old 01-31-2009, 08:18 PM
life is a temporary assignment
Yes your right.Make sure the tank has a good ground.If you ground out the wire.Your gauge should go to full.
Old 02-01-2009, 01:17 AM
JeffB's Avatar
gas gauge
I ran into the same problem.I ran a ground wire from one of the holdown screws on the sending unit to the frame and the darn thing worked!
Old 02-01-2009, 02:23 AM
i was thinking about a ground strap of some sort. now i'll have to try one.
Old 02-01-2009, 07:48 AM
poncho62's Avatar
Wiki Edits: 5
The body of the sending unit has to be grounded to complete the circuit.
Old 02-01-2009, 08:07 AM
could the brass screws i have attaching the sender to the tank prevent the sender from grounding?
Old 02-01-2009, 08:30 AM
poncho62's Avatar
Wiki Edits: 5
Brass is an excellent conductor.....run a wire from one of those scres to the cab body.
Old 02-06-2009, 01:20 AM
i finally got around to working on my fuel gauge today. i found out there was gas in the float on the sender. i soldiered up the hole and she works like a dream.
found a 51 chevy truck buggmann Engine 1 10-12-2007 06:35 PM
51 Chevy Truck Tilt Frontend 51Panel Body - Exterior 14 07-28-2007 10:34 AM
Guages are dead gtipton Electrical 4 05-09-2007 10:14 PM
Gas tank swap for 55 Chevy truck gator412 General Rodding Tech 8 04-05-2007 01:40 PM
47-48 chevy truck gas tank 49_chevy_truck General Rodding Tech 8 01-25-2006 04:56 AM
