51 chevy weatherstripping help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2006, 02:30 PM
I got a 1951 chevy 2-door sport coupe for restoration. The car came with almost two full sets of exterior chrome and interior window trim that was already removed but no headliner or weatherstripping. I ordered what I was told was a complete set of weatherstripping for the car from steele rubber products. When I was making sure all the seals were correct, I found the door seals only sealed the bottom half of the door (as if it were a non post car). I called the company and they said that the door seals are correct but I am missing the roof rail seals (for the top halfe of the doors). They also said there no one currently makes these seals. I am not sure what to do about this problem but I am sure other people have run in to this before, Please help.
Old 06-24-2006, 09:24 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Are you sure they came with a side/top door rubber seals? Many old cars did not come with rubber weather stripping, rather depended on a labyrinth in the door jamb and the fat upholstery welt to do the job. That is the way 50s Chevy pickups did it as did all the 30s cars I have seen.
Old 06-24-2006, 10:16 PM
I think you are right. Thanks for the help!
Old 06-27-2006, 10:06 PM
Ben,
My 49 Chevy does have top and bottom rubber. You can get it at the National Chevy Association on Arcade Street in St Paul Minnesota. I cannot remember the phone number off hand, but they have a web site. They also hit many of the shows throughout the country. There are other sources out there that I have found in the past. Good luck with your project.
Ron
51 Chevy 1/2T Pick Up - Front Clip Question mwskopf General Rodding Tech 10 10-14-2015 05:23 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
51 chevy truck suspension jsutton Suspension - Brakes - Steering 16 12-05-2004 09:50 PM
51 Chevy Truck Suspension jsutton Suspension - Brakes - Steering 4 12-02-2004 10:10 PM
Corvette rear end in a 51 Chevy p/u 3100 oldford Transmission - Rearend 2 04-30-2002 12:33 PM
