51 f-2 door lock - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2011, 04:47 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
51 f-2 door lock
I've got a 51 ford f-2 cab with f-1 frame and 6' box that I'am working on. The title says F-2. The drivers door doesn't have a outside door key lock. The right side has one. It came with and extra LT door with the hole for a lock. Is the door without lock a f-2 and the other a f-1? I'am not real sure if it will be and issue because I may shave the doors and go electric but was just curious what I've got
Old 04-13-2011, 06:42 PM
The early Ford trucks only had a key lock on the right side ... just like the Ford cars. In 1951, Ford came out with a 5 star option. The 5 star package gave you key locks in both doors, a visor on both sides and some extra chrome and trim. ALSO a pair of arm rests. SO ... having just one key lock is standard. You raise the door handle from the inside ( drivers side ) and then slide across the seat ... exit the cab and lock the door.
« hogman | wipers »
door lock question? cutthroatkid Body - Exterior 2 06-17-2010 03:54 AM
1999 F-350 Door Lock Trucknut Body - Exterior 5 02-21-2009 06:03 AM
Door Lock Problem ozzysback Interior 2 11-12-2006 04:51 AM
Car Door Lock Tutorial ? jboy Interior 1 06-24-2004 02:09 PM
Model A door lock fred56 Body - Exterior 2 05-05-2004 06:14 AM
