51 ford water pump replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2009, 08:12 PM
Granddad's51's Avatar
Last journal entry: Fender Skirts added
Lost the right side water pump on our 51 ford tudor. I guess this is a basic question but...when I put the new pump on with the gasket do I also use the RTV gasket sealer?
What is the best way to install?
Thanks for the guidance
Dan
Old 07-11-2009, 09:27 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I am sure some do and some don't, but i always use alittle on mine. JMO. Cole
Old 07-13-2009, 02:41 PM
moontanker's Avatar
Last journal entry: My 32 Ford pikup..
use
Use a bit cause you dont want a leak.Opinions differ but some of us can remember the smell of permatex shellack,Only under hypnoses though.
Electric water pump, what gpm? New fan? 84Z Engine 4 02-01-2007 06:30 PM
BB Chevy Coolant Leak @ Water Pump leejoy Engine 3 07-04-2006 02:10 PM
SBC short water pump vs long water pump and other questions Jag Daddy Engine 9 04-02-2004 10:29 AM
edelbrock water pump....does it cool better? mustang66maniac Engine 3 01-27-2003 07:49 PM
1932 Ford - ? about water pump clearance midnightrodder Engine 3 04-05-2002 07:17 PM
