51 Plymouth frontend - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2007, 04:16 PM
Does anyone know what to look for when checking the suspension on my 51? I do not have it in the yard yet and I am just trying to get as much info as I can before I start tearing anything apart. I am not planning on doing a frame off but I do want to upgrade most things (disk brakes, new shocks, springs, air-ride?, steering, etc.) This is my first rod and it is all new to me. I am used to obscenely high lifted trucks, not the low and cool. Any help would be greatly appreciated. Go easy on me for not seeing the light before!
Old 04-30-2007, 07:59 PM
BOBCRMAN@aol.com's Avatar
A general check of the front "A" frame bushings and upright supports is in order. New parts are still available. Relocate the front shocks.
Fatman Fab. has dropped uprights that will lower the car. Also disk brake kit and a Cavalier rack and pinion front end setup. These will make the old MoPar handle and stop.
Old 04-30-2007, 08:55 PM
Sweet! thats what I was hoping to hear. i want to be able to start, stop, and look good doing it! I think everything is pretty solid so a total frame and front end reconstruct should not be needed.
Another question I have is if I put the disk brakes on what else am I going to need to make it a power setup? Of course the master cylinder and booster but do I need to change anything in the rear, lines, etc.?
51 Chevy Truck Tilt Frontend 51Panel Body - Exterior 14 07-28-2007 09:34 AM
51 Plymouth question Heater Stick Electrical 7 04-29-2007 07:35 PM
Using 84 Mustang Frontend under 51 Ford Tudor bigbrowndog General Rodding Tech 1 09-18-2006 08:36 AM
51 ford frontend 51FordDuff Suspension - Brakes - Steering 3 03-10-2005 01:14 AM
Production total needed- 51 Plymouth Shaffer Hotrodders' Lounge 2 11-26-2002 04:40 PM
