Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 518 transmission not shifting
Old 02-19-2009, 07:19 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by fulltilt06
I have a Ram van with a 518 and I had a guy come and rebuild it. After he was done everything seemed ok at first then it would not come out of first gear. So know if you let it sit for a while you can go two blocks and everything is fine then it just starts getting worse and worse then all you have is first gear and reverse and nothing else. It doesnt slip it just will not shift after a couple of blocks. Any help would be appreciated !!!!!
some information on the vehicle would help
year , engine mileage on this vehicle
