518 transmission not shifting - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2009, 05:20 PM
I have a Ram van with a 518 and I had a guy come and rebuild it. After he was done everything seemed ok at first then it would not come out of first gear. So know if you let it sit for a while you can go two blocks and everything is fine then it just starts getting worse and worse then all you have is first gear and reverse and nothing else. It doesnt slip it just will not shift after a couple of blocks. Any help would be appreciated !!!!!
Old 02-19-2009, 07:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
some information on the vehicle would help
year , engine mileage on this vehicle
Old 02-19-2009, 08:38 PM
Sorry its a 1996 Dodge ram van 2500 5.9 it has 130,000 miles.
Old 02-19-2009, 10:12 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
would need to know if this trans is a RH or RE model.. RE unit would have a round electrical connector at the case 8 pins.
RH would have a 3 pin connector , usually oblong shape.
RE trans not shifting I would suspect the electronic governor pressure control.
Were the electronics replaced during rebuild?
I have many problems with aftermarket electronics on Mopar trans.. I only use the OEM stuff, especially the governor pressure control
Old 02-20-2009, 05:09 AM
tnsmith10's Avatar
when will it rain???
96 should be an re unit with the 8 pin connector. and it should have the round 4 pin govenor pressure sensor and transducer plugs 96-00, and 00-up should be the rectangular/square connector.
Transmission Sometimes needs help shifting Countilaw Transmission - Rearend 2 02-24-2007 01:08 AM
Any tips on dodge 518 Transmission hemi43 Transmission - Rearend 2 02-18-2005 09:28 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
camaro transmission not shifting chevcamz28newbie Transmission - Rearend 10 09-03-2003 11:34 PM
camaro transmission still not shifting chevcamz28newbie Transmission - Rearend 2 07-20-2003 08:33 AM
