Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A-518 transmission questions
  #35 (permalink)
Old 12-13-2011, 04:05 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Personally I'd use the cheap DexIII untill after the Shift Kit & Flush was done, then use the DexVI or if you plan on regular Trans fluid changes continue with DexIII or Type-F. The Shift Kit should firm & shorten up the shifts where Type-F may not be needed.
