52.3cc head # 14022601 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 12:56 PM
are these heads good?? can anyone tell me anything about them??
Old 01-22-2006, 01:03 PM
DoubleVision's Avatar
common heads on a 305. when used on larger small blocks, the small valve restricts breathing, if you had the 1.94 valves installed it would flow less due to the shrouding in the small chamber. These heads were designed for high velocity, small engines like the 305 need it to have decent low end torque.
When these heads are used on a 350, it`ll have explosive out of the hole power, but it`ll run out of breath at 3500 rpm.
Old 01-22-2006, 01:27 PM
i have it on a 350 it was a dog on take off but around 3000 it started screaming then about 4500 it ran out of power. i had the heads shaved .10 and the 1.94 valves installed
Old 11-06-2009, 08:03 PM
How?
how can anyone put 14022601 heads on a 350? They have 53 cc chambers. With flat tops they may come out like 12:1. Might work on the track, but not on pump gas
Old 11-06-2009, 08:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I think you mean had them shaved 0.010". lol
Anyway, the performance (or lack of it) you describe sounds more like a set of TALL rear gears, like in the low 2's.
Properly worked, the 601 heads should be on par w/the 416 heads that are often mentioned.
351W heads, how to identify from 289/302 RAW Engine 22 01-28-2010 03:54 PM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
SBO 350, Head Gasket help, with photos 360Camaro Engine 5 07-11-2005 08:29 PM
cylinder head cracked?!?!?!?! Blob Engine 4 01-24-2005 06:12 PM
Blown Head Gasket???? hmmm Engine 4 11-10-2004 10:20 PM
