'52 chev 3/4 ton dump truck, bed... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2012, 07:12 AM
Last journal entry: pics
just picked up a .52 chev 3/4 ton dump truck... i am thinking i would like to remove the wood constructed box and put a regular pick-up truck bed on it, still want to be able to use the dump mech...any thoughts and any ideas for places to look for the bed? thanks for any help you can give... will need misc. small parts for the truck also... all in all the truck is in very nice condition...
Old 03-30-2012, 09:40 AM
Wiki Edits: 31
Get a regular box for it and hook it up.. From the factory a 1/2 ton dump shortbed was available altho very rare, it did use the regular shortbed. 1 of them ( orig restored ) sits in a used car dealer showroom near where I used to work.
Old 03-30-2012, 09:47 AM
truck bed
thanks for the info, i am near stillwater, mn. where is the truck bed you spoke of?
Old 03-30-2012, 09:52 AM
truck bed
is the bed area longer on the dump box frame than a regular pick-up frame? my truck is a 3/4 ton, is there a differance betweewn thev 1/2 ton and 3/4 ton as far as bed size and what years would work/fit? maybe '48 through '52 +/- ? thanks for any help... first project like this for me...can you tell?
Old 03-30-2012, 10:15 AM
The 3/4 ton had about an 8 inch longer wheel base. So the running boards, running board aprons, and of course the bed. Behind the wheel the bed is the same, as are the fenders. If you google these trucks you will see that some have another bed pocket in front of the fenders, those are the 3/4 ton.
Old 03-30-2012, 12:41 PM
52 chev 3/4 ton truck bed
thanks brian, do you know how many years the bed design was the same? ie. maybe 1948 through 1952? or do i need to find the exact part ? bed for only 1052 3/4 ton (dump)...
Old 03-30-2012, 06:27 PM
The beds are exactly the same from 49-53 and the mid year 47-48 will be the same outside of a hole for the fuel filler on the right side above the running board.
Old 03-30-2012, 08:05 PM
truck bed... 52 chev 3/4 ton truck
thanks brian... and still can't get pics up???
Old 03-30-2012, 08:20 PM
If you are trying to upload them thru the "manage attachments" button when you post they are likely simply too big. That is the only cause of failure I have found.
Old 03-30-2012, 08:40 PM
pics
1952 chev 3/4 ton dump truck
1959 ford F750 Dump Truck mikecroskrey Hotrodding Basics 6 12-04-2011 09:57 PM
Field Find. Is this worth anything? 1937 Ford Dump Truck speedfoos Hotrodders' Lounge 17 10-15-2010 05:49 PM
41 ford dump truck davstrong78 Hotrodders' Lounge 1 11-02-2009 03:19 PM
What NOT to do in a 65,000 lb. dump truck Centerline Hotrodders' Lounge 9 04-30-2004 01:32 AM
