52 chev sedan front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2005, 03:04 AM
g, day guys im building up a 52 chev sedan , and bought a 350 motor and also going to run turbo 350 trans. can i run the origanal front end and suspension or do i have to change it .some of the guys down here in newzealand say that i have to put a ht holden front end in {from early holdens made in australia}. thanks for any suggestions .
Old 09-25-2005, 07:46 AM
Will I ever get it done?
Last journal entry: Hood
You can run the original front end. But it was built 53 years ago using 60+ year old technology. If I were you, I would get a MII kit. I am putting a TCI kit in my 41. Easier to install than a clip. Correct width. Modern ball joints, bushings, rack and pinion steering, disc brakes, etc.
Old 09-25-2005, 08:22 AM
Wiki Edits: 31
The original front ends work well with the small blocks, only seen a couple with MII kits installed, it will save you time and money, for 1, the disc brake kit is available for less than the MII compleate kit by about 400 bucks, you can also retain the original steering colum which I think looks good and compliments the car. You will only need to move the E brake system as it is in the way of a small block Chevy. I have a '51 Fleetline and did a lot of research on what to do to put a 350 in, but I decided to stay with my 235 inline.
1952 Chevy Sedan Delivery - Front End? MasterService Suspension - Brakes - Steering 9 04-25-2010 01:24 PM
front end too low mopar 36 Suspension - Brakes - Steering 21 11-19-2008 04:44 AM
tilt front end ds-unique Introduce Yourself 1 11-30-2004 08:13 PM
69 nova has a front end shimmy over 50mph sfrymoyer Suspension - Brakes - Steering 3 09-27-2004 09:55 PM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 01:45 PM
